raptor help
Old Feb 26, 2005 | 01:03 PM
wheelinguy2003's Avatar
Default raptor help
replacing carrier bearing/axle....my question is the bracket that holds the brake caliper on is not comming off easy....im not wanting to beat it off unless thats what needs to be done to remove it.....need a little advise...thanks in advance...
Old Feb 26, 2005 | 01:16 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
Default raptor help
the side that the brakes attach to is compression fit to the carrier and other side (which are one piece)
use a rubber or plastic mallet....or a piece of 2x4 and hammer to pound it off to the right....hitting the top and bottom until it pops off
then the other side will slide out
here
part # 7 slides off of part #2
Old Feb 26, 2005 | 01:25 PM
Default raptor help
okay...let me get this straight...so pound the bracket that holds the caliper off not the carrier bearing side...right?
Old Feb 26, 2005 | 07:30 PM
holeshot77's Avatar
Default raptor help
Think that is what he is saying..
Old Feb 27, 2005 | 03:25 PM
Bing's Avatar
Super Quad Patrol
Default raptor help
right
the two pieces come apart
left side goes to the left,,,,,right side goes to the right
you need to pull the axle 1st,,,,have you done that?
Old Feb 27, 2005 | 11:06 PM
rutelis's Avatar
Default raptor help
is it safe to ride when ur axel bearings r bad and ur axel is a lil wobbly or will that cause more damage and fry the bearings?
Old Feb 28, 2005 | 08:27 AM
Bing's Avatar
Super Quad Patrol
Default raptor help
it is highly recommended to not ride on worn out bearings
if you do,,,,it could make it harder to remove them when you do,,,and it could cause damage to the carrier itself (it is common to have to replace/repair the carrier)
on a raptor, it is common for the axle nuts to come loose,,,,,,and need to be re-torqued,,,,but if you are hearing popping and bad bearing noises,,,and still have a good bit of play,,,,,i wouldnt ride it at all
the bearings are cheap......and the process is pretty simple if you have a little mechanical ability
Old Feb 28, 2005 | 10:48 AM
Default raptor help
alright....carrier replaced and axle in....she now rolls...i guess with all the heat created the tolerances on the brake side was lessoned?...had to beat the crap out of it!!!
now next problem....go to start....nothing...obviously sitting awhile...drain gas...changed plug...cleaned stock air filter....pull dual carb...float bowl with red stuff ...cleaned and scrapped until ultra clean...go to start....it will sit and idle...but if you give it gas...wont rev...sounds almost if it went into some type of limp mode......is there such on this machine.....any suggestions?
Old Feb 28, 2005 | 02:48 PM
Bing's Avatar
Super Quad Patrol
Default raptor help
is the parking brake on (rev limiter)?
main jet plugged?
is fuel getting to both bowls?
i would check your fuel level on your bowls to be sure they are both getting fuel,,,,,,and the proper amount.
'search' the clear tube method for checking fuel level in the bowl (the needle/float may be gummed up too resticting fuel flow)
Old Mar 1, 2005 | 01:06 PM
maddog56's Avatar
Default raptor help
Sealed bearings with seals for 21.50 shipped to my door Priority Mail. Process is simple, just requires a lot of beating things with rubber mallets, hammers, and screwdrivers...
