Blaster bogs
Old Mar 3, 2005 | 10:59 PM
FaSsO's Avatar
Default Blaster bogs
anyone?
Old Mar 4, 2005 | 11:13 AM
FaSsO's Avatar
BUMP
Old Mar 4, 2005 | 02:35 PM
Shav0's Avatar
Dude it can't be rich when your jetting is lower then what comes from the factory.
Old Mar 6, 2005 | 01:17 AM
FaSsO's Avatar
i dunno man
Old Mar 6, 2005 | 01:42 AM
  #15
Bosch's Avatar
Try runnin it with the air box lid off.
Old Mar 6, 2005 | 02:05 AM
  #16
yamahawarriormods's Avatar
Originally posted by: Vinson581
you need to break it in for a good 2hrs at least, its gonna run like crapola untill the rings are seated, give it some time, and DONT give it more then Quater throttle or you could risk damageing the cylinder.
v581
i do believe in breaking it in but it should not run like crap because the rings have not seated yet.... i would have to so its a jetting problam when i rebuilt my yz i ran mint right away but i just took it easy on it and didn't put any heave loads on it
Old Mar 6, 2005 | 10:42 AM
  #17
Shav0's Avatar
If you did it right it should work fine when you are breaking it in. The compression will be down a little but overall power it should work fine. You can go above 1/4 throttle, and your encouraged to do so. However don't get to throttle happy. Try not to load the engine by lugging it in a low gear, and don't hold it wide open either. You need to vary the throttle position to give the piston time to heat and cool, that's what properly seats the rings.
Old Mar 6, 2005 | 10:59 AM
  #18
Vinson581's Avatar
the 2 quads i just rebuilt in the past 3 mounts, are one my buddies modded blaster.
when it started 2nd kick it idled ok , but had NO power to speak of at all, we kept taking it down the road slowly for about 10minutes, and letting the motor gain RPM;s on its own, staying at the reliative same throttle, then letting it cool completely. after about 1-2hrs it ran great, before that it didnt. but now it still runs great. mabey your pilot, is A. clogged. or B. to small.
i also did my friends 300 explorer 2 stroke, and that thing also ran like crap untill about 2-5hrs of break in, it took longer for some reason? but it runs really good now.
i think breakin is KEY and if you didnt do it right then it could have problems with the motor.
listen to what chavo says he really knows blasters good.
v581
Old Mar 6, 2005 | 11:08 AM
  #19
Shav0's Avatar
Did you use alot of oil on the cylinder and piston skirts when you put it back together? Sometimes people use to much oil and it takes a little longer to burn off.
Old Mar 6, 2005 | 10:24 PM
  #20
FaSsO's Avatar
NO MY BUDDY ACTULLY DIDNT PUT ANY ON but he washed it with soap
