Raptor wheel flip...
Old Mar 3, 2005 | 05:49 PM
PolishCowboyPL's Avatar
Default Raptor wheel flip...
Do the stock rear rims on a Raptor 660 have a positive offset or negative...? What I was thinking, is if it is possible to flip the rims around and bolt them the other way.. Would this cause them to stick out more or in.. I don't have my raptor hear and I can't remeber if the rims are deeper looking into them or looking out(in from the side, out from where the axle is)
I think it wouldn't work but I was wondering, becuase that could at as wheel spacers..
MIke.
Old Mar 3, 2005 | 06:26 PM
Rider1169's Avatar
It will make it a lot narrower. So stock, the deep offset of the rim is facing outward. So by flipping them, it will only make it about 2-3 inches narrower. The fronts make it about 2 inches wider a side when flipped, but the rear rim offset is different.
Old Mar 3, 2005 | 06:46 PM
Thats what I figured, I just couldnt confirm it without my machine, I heard that the front flipped works for gain.
Old Mar 5, 2005 | 12:00 AM
yamahawarriormods's Avatar
i flipped the rear rims on the warrior worked sweat but i dont think u can flip the front cause the valve stems will hit your disc brakes
Old Mar 5, 2005 | 12:05 AM
TrailBlazerguy250's Avatar
you have to drill out another valve stem opening for the fronts on the opposite side or the rim , then patch the existing hole
Old Mar 5, 2005 | 12:08 AM
Rider1169's Avatar
Or, flip the vavlestem inside out on the front rim, then drill another hole and insert a new vavlestem on the deep side of the rim.
STLyamwar
Jul 25, 2020 04:44 AM
Aug 25, 2015 11:16 PM
Aug 21, 2015 01:23 PM
black_thunder
Jul 22, 2015 06:01 PM
yambam13
Jul 4, 2015 01:49 PM
