Modding my New Raptor 350???
Old Mar 11, 2005 | 10:43 PM
  #21
jubbis18's Avatar
Default Modding my New Raptor 350???
Yeah I'm really lookin to throw an aftermarket air filter and possibly a pipe on my raptor 350, and I have several questions. First of all, what exactly is the difference between the K&N filter and the Pro Design? I'm kinda confused on which is which. I usually ride in pretty dusty areas, so I don't think riding with the Pro Design filter-to-be with an outerwear on with no lid is a good idea, correct? On top of that, supposing I can scrounge up the money to even get the filter, plate, outerwear, and pipe, I have no clue whatsoever on how to re-jet my carb. Is it something I can learn, or am I better off taking it to a shop and having them do it?
Thanks,
Justin.
Old Mar 12, 2005 | 12:12 AM
  #22
Fastblasterboy's Avatar
Does any one with a warrior have this problem, When you are sitting there ideling and you punch it all the way really quick it like boggs way down? 2 of my buddies have this problem and they are jetted correctly. Even when they got them new they still did it. Can you fix this?
Old Mar 12, 2005 | 12:47 AM
  #23
VelociRaptor350's Avatar
Thats the carb, everyone warrior i have ever ridden does the same thing.
Old Apr 17, 2005 | 08:25 PM
  #24
Offroadrapter's Avatar
I got the Pro Design Pro Flow Air filter and it works great. You can really feel the diference in acceleration. It is totaly worthit and it helps me alot since I ride off road.
Old Apr 18, 2005 | 07:26 AM
  #25
Glad to hear it worked out for you. You can try dropping the front sprocket down a tooth to get a little more punch off the line.
Old Apr 18, 2005 | 10:41 AM
  #26
86LT250RFatty's Avatar
a pro-design filter gives you a alluminum bracket which you Screew into your airbox, then you get the supplied K&N which clamps onto the adapter. It gives you better performance, and better dirt protection. It also gives you the choice of running with the airbox lid off or on. If you get the stock replacment K&N filter its so/so, it wont block dirt off nearly as good as the pro-flow, and you have to run with your lid on. Also, i run at the dunes, and VERY VERY sandy conditions and i have my lid off, great bump up in HP, just clean your filter regularly and you will be fine. [img]i/expressions/face-icon-small-smile.gif[/img]
bmxatv10
Oct 14, 2022 06:23 PM
Sep 23, 2015 06:23 AM
black_thunder
Sep 22, 2015 07:59 PM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
