how do you get studs out?
Old Mar 16, 2005 | 12:06 AM
ImASissy's Avatar
Default how do you get studs out?
I am trying to get the studs out of my hubs... i figured it would be easy just to knock them out, but it aint working and i dont wanna bend stuff. i let them soak in wd40, but still no luck. is there a trick?
Old Mar 16, 2005 | 03:00 AM
yamahawarriormods's Avatar
...... try using 2 bolts or lug nuts why do u need to do this
Old Mar 16, 2005 | 10:31 AM
ImASissy's Avatar
beacuse i made the mistake of buying bolts from the hardware store, and i tightende them too tight and they stripped me studs. what do you mean use two bolts or 2 lugs
Old Mar 16, 2005 | 11:27 PM
OhHell's Avatar
Get a bigger hammer. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 16, 2005 | 11:46 PM
maddog56's Avatar
I'm not sure what the stock hubs are made of, but I'd consider taking them out with a torch.
Old Mar 17, 2005 | 03:45 AM
if u can get 2 lug nuts on to the studs crank them down tooo gether and then start to un screw the in side one.... hope i could explain this better
Old Mar 17, 2005 | 12:58 PM
2004LEBANSHEE's Avatar
Vice grips
Old Mar 18, 2005 | 05:43 PM
DaBeechMan's Avatar
if i remember right a banshee stud just presses into the hub correct? If so thread a nut on the stud and hit the nut with a hammer (this way you dont damage the thread). If i am wrong and its a threaded stud just do like the other guy said and jam nut it. To jam nut something you want to thread one nut on first, then follow it with another nut, tighten the two nuts together and then thread the outter most nut in
Old Mar 18, 2005 | 09:00 PM
Six2notScaredofU's Avatar
They just press in. I have an extra set of Rear Hubs if anyone needs them (stock).
Old Mar 19, 2005 | 08:08 PM
ImASissy's Avatar
how mcuh
