banshee stroker kits
Old Mar 16, 2005 | 12:35 AM
NastyNate03's Avatar
Default banshee stroker kits
hey im modding my 2003 banshee i got a air filter and single 35mm carb right now ill be getting pipes and reeds soon now i want to look into a stroker kit and porting for my banshee i want one that will really boost my power for my money im on a budget of around $1000 for the stroker kit what ones do you's like heres one i found on ebay what do you's think of it how much hp do you think it will make with pipes reeds dual 33mm carbs porting cool head and k&n filters http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Old Mar 16, 2005 | 01:18 AM
2004LEBANSHEE's Avatar
a 4mill and a good port you'll beat anything but bigger shees. Hp is all in porting and setup and nobody could give you a acurate answer. youll need to hit the dyno. oh and $1,000 is probably not enough.
Old Mar 16, 2005 | 10:05 AM
what do you think of this crank and everything in this link http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW it looks like it will be good im going to be getting my cylinders ported i want to bore it or something also but i heard banshees blow up alot if you get them bored what would you's suggest me to do can someone post some links to web sites that have good stroker kits and bore kits and maybe some good places to send my cylinders to be ported and maybe bored
Old Mar 16, 2005 | 01:10 PM
enFORCER's Avatar
You can but a new 4 mill stroker for about $500.... The spacer plate cost about $40 bucks.... You can use your existing pistons and head.....
Old Mar 16, 2005 | 04:00 PM
enFORCER your lucky you have a 535 cheetah i want that kit so bad it sounds bad *** and looks to be what i need to be satisfied i would buy it but its to much i only can spend around the $1000 area i want to get a big bore kit and a stroker crankshaft i want a bigger size crank then a 4 mill
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Alex G.
Sep 16, 2015 12:13 PM
Lou Domenech
Sep 11, 2015 06:35 PM
Jaymc
Sep 11, 2015 07:45 AM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
