110 octane gas
Welcome to the forums Fattie. He's right. 110 octane will slow you down...unless you have a high compression piston. You should try an 87 octane compare to like a 91 octane. It may run better. Lower octane fuels have a higher flash point.Works better with low compression.
I have a Ross 10.75 to 1 piston and I run 87 octane but I have a bigger bore so I'm not sure...Try a 91 octane and see. Plus it's cheaper.
RIDEFREAK1 your a little high on octane with a true 10.75. Like ItalianStallion does, it should run on 87. You really should have no problem at any time, under any condition with 92.
It's always good to go a little higher than needed when it comes to these things, but never lower.
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
