raptor jets
Old Mar 18, 2005 | 11:41 PM
Seibert51's Avatar
Default raptor jets
I am getting a new raptor and i am goin to run it like this , ct racing pipe ,header, k&n , and jet it. my question is what shood i jet it too. o ya i live in south texas. corpus christi
Old Mar 19, 2005 | 09:43 PM
maddog56's Avatar
Default raptor jets
Depending on what you bought, they will send the jets with it along with instructions.
Old Mar 19, 2005 | 10:49 PM
redwingsrule05's Avatar
Default raptor jets
What elevation are you at? I have about the same set-up i just jetted and it took 160/165 mains, 25 pilots, and needles on the third clip, air screws out 2.0 on the left and 2.5 on the right. I"m in New Mexico at 5200 feet.
Old Mar 19, 2005 | 11:41 PM
Seibert51's Avatar
Default raptor jets
if i have never did the jets before do u think the instructions will be able to show me how or am i better off just taking it in. thanks and the sea level can be that bad cause im about 10 mins away from the beach
Old Mar 19, 2005 | 11:53 PM
Default raptor jets
You need to pull off the battery, seat, rear and front plastics. Once you have removed the air box, take off the gas tank. You will see two black lids one for each carb on the top. Inside these are the needles. When you dissconect the carbs and flip them over, you need to remove 4 phillips head screws on each carb to gain access to the main jets and pilot jets. I would go with a 25 pilot jet and 160 on the right carb and 165 on the left carb. I just put the carbs air box and tank on to test it each time until i get it right. Then you can reassmble plastic ect completly because you probably will have to change the jetting more than once to get it right. Here is a good page with pictures on how to do that and the airbox.
http://www.off-road.com/atv/projects...ce/intake.html
Old Mar 19, 2005 | 11:58 PM
Seibert51's Avatar
Default raptor jets
thanks for the help dude
Old Mar 20, 2005 | 11:56 PM
RDZ350's Avatar
Default raptor jets
I had an 01 Raptor with a pipe and K&N.I'm think the smaller jet (160) goes in the left carb.CT should be able to help you.You can run bigger jets if you get rid of the air lid.Pro design makes a air filter kit that will allow you to do that.Get the kit with the K&N filter.I had mine jetted at 180/185.That might be too rich where you're at.
Old Mar 21, 2005 | 01:02 AM
CTracingraptor's Avatar
Default raptor jets
if you have the Ct jet, it will tell you how. but otherwise run third clip from the top on a 165,170 jet.
bmxatv10
Oct 14, 2022 06:23 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
