Blaster help please
Old Mar 19, 2005 | 04:49 PM
yrrej's Avatar
Default Blaster help please
ok......so i needed to clean my k&n airfilter after all the mud splashing into my airbox and i needed to clean my carb.........so i went and bought carb cleaner and k&n airfilter maitnence kit........so i did the airfilter and cleaned it up and let my quad idle without the airlid or airfilter for about 1 min.......sounded funny but neways i put my airfilter back on and my quad was bogging down........sputtering had no power........then i waited a little wile and i started it again...........well i tried to IT WOULDNT START! so i took out my sparkplug and it was charcole black i think thats rich but not sure........so i cleaned it with a brush and gas and put it back in.........it started but would turn off if i didnt stay on the gas........it wouldnt idle at all............so i put the idle all the way up so it would idle normall and it did and i was hoping that by then the carb cleaner would have gone through.........(its the kind that you pour in the gastank) and i drove it and it ran like $hit...........idk wat else to do?!
Old Mar 19, 2005 | 05:06 PM
Shav0's Avatar
You let your quad idle for 1 minute with no airfilter on it at all? Why..
Old Mar 19, 2005 | 06:26 PM
yrrej's Avatar
was tempting.........i no.........im dumb...........wat could this have done?
Old Mar 19, 2005 | 07:03 PM
Shav0's Avatar
There is probably alot of crap that go sucked into the motor, but I don't think thats causing the problems your experiencing.
Old Mar 19, 2005 | 07:17 PM
yamaharaptor350's Avatar
what u got mud in your airbox and u had no outerwear or pro design clamp on kit???
Old Mar 19, 2005 | 07:32 PM
yrrej's Avatar
idk....i just had my k&n in
Old Mar 19, 2005 | 07:35 PM
wait did ya have your lid off??
Old Mar 19, 2005 | 10:20 PM
yrrej's Avatar
no at that time i had my lid on.........the only way mud got in was from that lil drainplug that fell out..........but it got in there pretty good
Old Mar 21, 2005 | 05:29 PM
NECTrider's Avatar
Buy a new spark plug... its only 2$ and if that dont work.. well.. its a lesson learned.. never let it run without the filter! haha let me kno if it works.
Old Mar 21, 2005 | 07:06 PM
MSGT's Avatar
Your diagnosis was correct: black sooty deposits on the plug means its too rich. Putting the filter back on made it more so (cut down on air flow). Either there is a problem with the float level inside the carb, or you have a sudden lack of vacuum. My vote is for the first one. Running carb cleaner through the tank will only clean the fuel path into the carb - over time. Check the float level and the cleanliness of the needle & seat; if it won't shut off, it will flood. If everything in the carb checks out ok, start checking for vacuum leaks, 2 strokes are very sensitive to this problem! Even so much as a loose oil cap can cause problems (rough running, hard starting, false rich condition). Check your air filter too; too much oil can cause its own problems.
