Grizzly intake on a raptor
Old Mar 21, 2005 | 08:58 PM
AustinONeal's Avatar
Default Grizzly intake on a raptor
could you put a grizz intake on a raptor to make it where you can use one carb?
Old Mar 21, 2005 | 09:37 PM
maddog56's Avatar
Do you want the grizz intake or the whole grizz carb setup? You already can use aftermarket intakes from edelbrock for a single setup. I dont know if the head is the same, I believe it is just with a different cam. So if the head has the same intake holes in the outside of the head, I dont see why not.
Old Mar 21, 2005 | 09:46 PM
yea i was gonna try to go with the whole grizzly carb set up the mechanic at little sahara was telling me about it and i thought i would mention it on here
Old Mar 21, 2005 | 10:43 PM
maddog56's Avatar
Its a 42mm, which seems awfully small for an internally modified raptor. I would think you would end up losing power, but I've never seen anyone try it so I couldnt say.
Old Mar 22, 2005 | 04:50 PM
SCHOLLE's Avatar
Hasn't given up on the 660 just yet...
The ports are different. They are opposite from the raptor head. Several people have asked about it in the past. I have not personally looked into it but was given some info bu other that went with a single setup.
Old Feb 6, 2020 | 09:11 PM
Javier Villalpando's Avatar
Default Raptor intake manifold
I bought a NICHE 660cc Big Bore 9.1:1 Compression Cylinder Kit for 2001-2008 Yamaha Grizzly 660 Rhino 660 Raptor 660R and said it would fit my 02 raptor but it’s for a grizzly 660 intake manifold can I do anything to make it fit my raptor dual carb
raptorracing
Feb 10, 2004 09:39 PM
NY02Raptor
Jan 26, 2004 09:48 AM
trapland
Jan 12, 2004 10:33 AM
Ward660R
Jul 14, 2003 08:40 PM
