easy blaster freemods
Old Mar 22, 2005 | 12:23 PM
2strokegood89's Avatar
Default easy blaster freemods
i have an 2002 yamaha blaster. it has fmf sst full exaust system, aftermarket jets, k&n filter, modded airbox, maxxis razr tires front an rear, itp wheels front an rear, dg grab bar an bumper, renthal handle bars, an acc nerf bars. i have heard of people tinkering with the mixture an electrical to squeeze a few more ponies. any help with this will be appreciated
Old Mar 22, 2005 | 01:05 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
If you haven't already, get an oil block off kit and premix your gas. This will not only increase your performance but also prevent engine damage. You'll know when your oil injector stops worrking when our engine seizes.
Old Mar 22, 2005 | 05:06 PM
Shav0's Avatar
How do you gain extra peformance from switching to premix? Either way your still getting the oil to the cylinder. Maybe if you switch brands and lean on the oil mix a bit by running 40 or 50:1
Old Mar 22, 2005 | 05:09 PM
Pirate Biker
Limping Rider!
You get extra performance because you are getting an accurate mix with premix gas/oil. With the blaster's injection system you invariably get too much oil into the mix.
Old Mar 22, 2005 | 06:08 PM
Shav0's Avatar
And how do you purpose that happens? The pump is built to increase the output of oil as the RPMs require. No performance, just peace of mind.
Old Mar 22, 2005 | 07:31 PM
MSGT's Avatar
Like anything else mechanical, it requires periodic maintenance and adjustments. It also requires to stay clean in order to work right.
Oil injection is not new, my 1974 Kawasaki H1 500 had it and it worked fine. Occasionally it oiled my boot, and I changed-out the crush washer, that's all.
exmotocrosser
Sep 13, 2019 06:12 AM
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
exmotocrosser
Sep 26, 2015 08:18 AM
nastyblaster100
Sep 13, 2015 01:19 PM
