what do for my rejetting on my warrior a 150 or 140
Old Mar 22, 2005 | 07:00 PM
mywarriorripps's Avatar
Default what do for my rejetting on my warrior a 150 or 140
without any rejetting it used to be a 145 and it didn't run nice at top speed it like almost bogged but and backfired now i put in a dyno jet kit and put in a 144 jet but goes nice at top speeds but backfires when i deaccelerate (let go off the throttle) a big yellow flame so what should i do a 140 or a 150 please help
1999 yamaha warrior
dyno jet kit
dg bumper
dg nerf bars
dg baja skidplates
itp mudlite tires
cobra megaphone exhaust
mbrp powertech 4 header
shock covers
3 ich wheels spacer
k&n air filter
Old Mar 22, 2005 | 07:09 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
try a 147.5 main. and whe n u decel it's bumping unused fuel into the header and when it gets fresh air it reignites.. this can be caused from btoha lean AND rich condition..
Old Mar 22, 2005 | 07:11 PM
Speedy2222's Avatar
also make a run to WOT in 6th ( just breifly after u install the 147.5) and then shut it off IMEDIATELY and check what color the plug is Color Guide
Old Mar 23, 2005 | 08:34 PM
if i put a 150 in would run way richer wouldn't it were gonna try with a 140 and if this doesn't work will put the 144 back and drill holes in the airbox it wont decrease hp with a smaller jet or will it decrease hp
because when we had the 145 in it backfired way more and didn't run at maximum speed
1999 yamaha warrior
dyno jet kit
dg bumper
dg nerf bars
dg baja skidplates
itp mudlite tires
shock covers
3 ich wheels spacer
k&n air filter
Old Mar 23, 2005 | 08:57 PM
yamaharaptor350's Avatar
i run a 138 dynojet on mine... look at my mods if ya wanna know what i got
Old Mar 23, 2005 | 09:21 PM
2phast4u's Avatar
if you where bogging in the top u should have went bigger thats wat i did i was bogging at the top then i added a pipe and went up 1 on the main everything is perfect now
Old Mar 23, 2005 | 09:26 PM
Speedy2222's Avatar
stock is 145... y would u run a 140?
Old Mar 24, 2005 | 07:09 PM
tomorrow were trying the 140 because if it is backfires it means it has unused fuel so we have to go with a smaller jet cause with the 144 it runs way nicer at top speed than the 145 and if this doesn't work will try the 144 again with drilling a big hole in the airbox. is the backfiring possible of no back pressure it is all straight.
1999 yamaha warrior
dyno jet kit
dg bumper
dg nerf bars
dg baja skidplates
itp mudlite tires
shock covers
3 ich wheels spacer
k&n air filter
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
01ssls1
Sep 22, 2015 06:50 AM
