detinated left piston on the banshee
Old Mar 24, 2005 | 10:45 PM
TrailBlazerguy250's Avatar
Default detinated left piston on the banshee
what should i do , ita a big mess
Old Mar 25, 2005 | 12:31 PM
thinking of going back to the utility bikes now, not sure , what yall think ?
Old Mar 25, 2005 | 12:43 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
ooo u ran it to rich.... oooo you're in trouble now...
Old Mar 25, 2005 | 12:47 PM
if anything i ran to lean , but that wasnt it , i sucked up some water in my box and it got into the carbs and ran through the motor and cooked it
Old Mar 25, 2005 | 06:41 PM
Bubba297's Avatar
Make sure and check the lower rod bearing on the crank. With it being an 87 that could sure be the cause. I've seen it happen several times on older machines.
Old Mar 25, 2005 | 08:03 PM
update : needs to be bored and needs a new piston as far as we know , might need a crank , if it does need a crank iam parting it out , anyone know of anyone maby looking for banshee parts ? i got all you need
Old Mar 25, 2005 | 08:08 PM
also it didnt suck up water , it was b/c i was told from the dealer that i could run 93 and i was suopose to only run 110 or higher
Old Mar 25, 2005 | 11:36 PM
FoxForma's Avatar
If you get it fixed, you should get it bored and a port job so you can run 93 octane. I dont see why you would have to run 110 or higher tho but eric gorr can solve that octane issue with a port job. I think its ericgorr.com but i'm not sure. Good Luck with it
Old Mar 25, 2005 | 11:45 PM
hey thanks man , iam going to a .40 over . it was cuz of the Cool heads on it , they re domed to 20cc
Old Mar 26, 2005 | 01:47 PM
its being rebuilt ! then sold for $2000 !
nastyblaster100
Sep 13, 2015 01:19 PM
atvcollector
Sep 8, 2015 05:11 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Canamaniac!
Sep 4, 2015 06:44 PM
Jason Richards
Sep 4, 2015 06:17 PM
