raptor cranking problem
Old Mar 25, 2005 | 07:51 AM
hellrod's Avatar
Default raptor cranking problem
HI I have a raptor 660 2002 just recently when going to ride it wouldnt start when it turned over it just made a vrrrrrrrrrrinnnng sound so i checked the starter and all gears in crankcase nothin showin wrong i even reversed the starter gear thinkin the teeth could be worn the funny thing is if u turn the crank to the compression stroke and put everything back together and push the start button it makes a grinding sound once or twice and starts but cut it off and hit the button and it makes a terrible grinding sound and then it sounds like the starter cant connect any help would be appreciated.
2002 raptor 660
2005 rm125
2005 blaster
2005 rm50
Old Mar 25, 2005 | 08:38 AM
TheRaptorMan's Avatar
Bad news... Its your "one way starter gear"
If you are going to have to replace it I have heard nothing but good things from the LA Design one way it is supposed to be alot tougher then the stock one. I will be going with the LA when I have to change mine...
Later,
Mike
Old Mar 25, 2005 | 10:23 AM
86LT250RFatty's Avatar
yea its your one-way, typical on 660r's. go to www.raptortranny.com you can purchase the L&A one-way on their and it gives you instructions on how to install it, good luck.
skinnyr6
Aug 25, 2023 02:18 AM
Countrygirl1976
Jul 13, 2015 10:08 AM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
yambam13
Jul 4, 2015 01:49 PM
