Grizzly 80 ?
Old Mar 25, 2005 | 11:51 PM
OrphanMaker's Avatar
Default Grizzly 80 ?
Don't even have a full tank of fuel through my son's Grizzly 80 and have already went through 2 plugs....seems to be flooding out .....left us stranded in the woods tonight ......Plugs are really Black......
Is this normal for new 80 cc motor? I thought 4 strokes didn't fowl as easy ?....
What could be causing this ?
Also...its a 3 speed.....somtimes very hard to change gears...and get into Nuetral....
Just thought I post before I take into Dealership....
Thanks....
JP
Old Mar 26, 2005 | 12:05 AM
yrrej's Avatar
maby the factory jetting is off...........if its black its running lean i think im not sure..........but it has to do with the jetting in the carb........find out the stock jet in it and then check yours out......
Old Jun 27, 2005 | 07:32 PM
TnIceman's Avatar
Orphanmaker,
I am sure you have fixed the problem by now but I just saw your post and have had the same issue.
If you have not fixed it, open the front plastic cover and open the airbox, remove the restricter plate with 7 small holes in it and dont put it back..
It will fix your problem and make the machine run a 1000X better.
Dealer should have done it for you.
Jeff
Old Jun 27, 2005 | 10:28 PM
Thanks Jeff..
I figured that one out....
So far its still running Great .......
Just got to keep gas in it ..
Thanks
JP
Pgbama11
Jan 16, 2016 08:19 AM
cboler9
Sep 24, 2015 08:35 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
Pgbama11
Sep 10, 2015 08:20 AM
rawbdiggity
Sep 7, 2015 12:05 PM
