02 Grizzly Pulling To The Right
Old Mar 30, 2005 | 11:25 PM
02Grizz2345's Avatar
Default 02 Grizzly Pulling To The Right
Has anyone had a problem with their grizzly pulling to the right when you let go of the handle bars? If I let go of the handle bars it will immediately go the right. It happens at any speed. I have checked the air pressure and both front tires have 5 lbs. Does anyone have any ideas of what I can do? Thanks
Old Mar 31, 2005 | 12:04 AM
extremerider2811's Avatar
if theres a sway bar, that could be the issue, but take her in for an alignment.
Old Mar 31, 2005 | 12:10 AM
redneckcav24's Avatar
I rolled one nose first before and it bent the sterring shaft causin it to pull. Check that and make sure ur axle isnt damged.
Old Mar 31, 2005 | 01:27 AM
Andy Bassham's Avatar
you could have a bent tie rod, or its just out of alignment. Can you tell by looking head on at your front tires if one looks to be pointed to a different direction when the handlebars are centered?
greg74
Sep 10, 2019 03:03 PM
Jul 28, 2015 12:12 PM
RticKwad
Jul 21, 2015 03:00 PM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
