what to use when cleaning a head and cylinder?
Old Apr 2, 2005 | 01:11 PM
King660r's Avatar
Default what to use when cleaning a head and cylinder?
I have an old DR350 motor that I am rebuilding as sort of a hobby. What should I use to clean the head, valves, etc..?
Old Apr 2, 2005 | 01:17 PM
wheelinguy2003's Avatar
carb cleaner works better than gas or kerosene imo.....use a bowl to capture while spraying this way youll be able to reuse for other little parts untill it evaporates....
Old Apr 2, 2005 | 01:47 PM
Doctorturbo's Avatar
GOT BOOST!
Sand blaster and solvent. Some people use walnut shells for media. If you don't have a blaster then, like wheelinguy2003 said, carb cleaner works good.
Old Apr 2, 2005 | 01:52 PM
hey doc...what are the walnut shells used for?
Old Apr 2, 2005 | 06:21 PM
GOT BOOST!
wheelinguy2003 there are many media types on the market. I used to be an aircraft mechanic and had the "fun" job of cleaning all of the cylinders when they came in. We had 3 different blasting machines. 1 was coarse sand. We blasted all cylinders and heads with that. 1 was glass and we did the tops of the pistons with that (taped up the ring lands). 1 was walnut shells and we blasted the ring lands of the pistons with those.
The walnut shells were very mild and will not harm aluminum. They sucked for taking heavy carbon build-up off though.
BTW, another thing that I have used is a small round wire brush on a die grinder. This works VERY well.
skinnyr6
Aug 25, 2023 02:18 AM
Sandman2.0
Jul 21, 2015 09:03 AM
Jul 7, 2015 11:00 PM
ranvette
Jul 4, 2015 06:13 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
