*HELP, 350cc motor (Wolverine & Warrior)
Old 04-04-2005, 01:50 AM
VelociRaptor350's Avatar
Default *HELP, 350cc motor (Wolverine & Warrior)
Super rich, you may just need a new plug, it dosn't look like that one is firing too good
Old 04-04-2005, 02:03 AM
Daranello75's Avatar
But will a bad plug cause that loud ticking noise????
Old 04-04-2005, 02:13 AM
AZDUNERAT's Avatar
The ticking sounds like your valve screw has come off, common on these motors. You need to dissaseble the bike some(take off the fuel tank) and open the valve cover and there should be a screw on each one of the valve adjesters. That is what happened to my wifes cousins bike, only his screw worked its way into the case(crappy). I would try that. As for the screw when was the last time you cleaned your air filter. You could be chocking the air flow causing the rich condition
Aaron
Old 04-04-2005, 03:15 AM
Originally posted by: AZDUNERAT
The ticking sounds like your valve screw has come off, common on these motors. You need to dissaseble the bike some(take off the fuel tank) and open the valve cover and there should be a screw on each one of the valve adjesters. That is what happened to my wifes cousins bike, only his screw worked its way into the case(crappy). I would try that. As for the screw when was the last time you cleaned your air filter. You could be chocking the air flow causing the rich conditionAaron
Filter is clean, i just remembered my last ride in October i accidentaly rode with the choke half on, could that be where I got all the carbon build up?
Is it expensive to have the dealer fix the valves??
  #15
Old 04-04-2005, 03:20 AM
Aythinng at the dealer is expensive, they get upwards of 70 bucks an hour for work, let alone parts. i would sggest getting a repair manual for your atv and do it yourself.
  #16
Old 04-04-2005, 12:05 PM
I want to but, I want to be sure I know the exact proplem first before the tear down
  #17
Old 04-04-2005, 08:17 PM
  #18
Old 04-04-2005, 08:58 PM
nhmudbear's Avatar
You might be able to look at some manuals online at yamaha company website .I have looked at owners manual for snowmobiles on their site this winter.
  #19
Old 04-05-2005, 09:14 AM
95wolv's Avatar
First let's get back to the symptoms you described : revved up, black smoke, let off gas, backfired,now runs badly, ticking noise. I fully agree with everyone else, sounds like carbon fouling, the plug shows that, now for the rest, it may be possible a small hard carbon chunk got caught under the exhaust valve, not letting it close all the way, so now you have clearance in your rocker arm, so now it ticks while idling. First, I would pull and clean out the carb, getting all the passages cleaned out, then take the fuel line from the tank, and drain out all that nasty old fuel into a bucket. Fill the tank with fresh clean gas, and put about a half can of Sea Foam in with it. Start it up and let it run, blip the throttle occasionally, hopefully the Sea Foam will loosen up the carbon in the cylinder, and maybe clear out the valves, you may need to go for a ride to really warm it up. If it still ticks bad, like azdunerat said, you'll have to pull the tank and check your valves, the lock nut may have worked loose, and it will only get worse if you don't check it out !!!
  #20
Old 04-05-2005, 11:42 AM
Thanks for all you help, I'm going to go buy sea foam now, can you spray the stuff right into the carbs or only in the tank? And how long should I run the motor with sea foam in to see if the problem goes away?
Quick Reply: *HELP, 350cc motor (Wolverine & Warrior)
