Blaster shocks
Old Apr 7, 2005 | 10:37 AM
DirtRyder420's Avatar
Default Blaster shocks
would stock 250r front shocks fit on a blaster if so would it be any better then stock blaster shocks? I am looking for a cheap way to improve my suspension
Old Apr 7, 2005 | 03:09 PM
chazekxt's Avatar
a lot of people use banshee shocks they a little better then blaster shocks
Old Apr 7, 2005 | 06:16 PM
lethaface's Avatar
there is a few shock's that will interchange with your blaster..
Front- Banshee shock's is the best upgrade beside's aftermarket.
Rear- 400ex, cannondale cannible, Kfx, Ltz400, and 250R -all these are said to be a hell of alot better than the stock rear shock. The 250r shock will set your rear end up a little bit higher than the other's..They all require a little bit of work to get on but nothing to serious.
Old Apr 7, 2005 | 07:09 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
A 400ex rear shock will fit on a Blaster?
Old Apr 7, 2005 | 07:34 PM
chazekxt's Avatar
yes it will with a little mod to it
Old Apr 7, 2005 | 09:21 PM
NECTrider's Avatar
Dont buy warrior front shocks.. haha i made that mistake on my old one and it was worse then if i just bolted two metal rods in... my $.02
Old Apr 7, 2005 | 09:36 PM
Shav0's Avatar
The 250R rear will bolt on with only a little modification to the lower mount.
Old Apr 11, 2005 | 09:43 AM
Hell yea! thanks for the info yall ...(gotz me sum ebaying to do)
Old Apr 12, 2005 | 01:42 AM
Monolith's Avatar
250r front shocks are way too long.
as for the 250r rear, you can only use 1987 or newer ones because the older shocks are lionger and will jack the rear end way up. i have one form a 87, works good and raised the rear about 2", but then when i sit on it, it sags to normal ride height.
Old Apr 22, 2005 | 09:30 PM
BlasterMX777's Avatar
Warrior shocks do or don't fit? My buddy has a 1987 warrior with works shocks all the way around and me and him were going to swap my stockers for his works. will these fit? It will come with Front and back. thanks
