Tightening 02 warrior chain
Best I could suggest to you is to be somewheres really quiet and kneel down behind the quad .. pull on the grab bar and try to isolate where the noise is coming from
It could be the top shock bushing, lower shock bushing, swingarm pivot or on the linkage .. OR .. something that just came to my mind .. is your chain lubricated? If not, that could squeek when the suspension is working .. as well .. check your rear wheel hubs .. the metal-on-metal action of a loose hub can cause a squeeking as well.
the squeak is porolly the bushing on the lower of the bottom of the shock.. what u should do is.. pull the bottom bolt out and pack it full of lithium grease and put the bolt back in..
#19
Originally posted by: NLWarrior01
Bearings aren't that serious .. they're cheap and relatively easy to replace ...
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
