Quick Question: is the '03 Warrior a 4-stroke, or a 2-stroke?
Old Apr 8, 2005 | 10:20 PM
jessejames's Avatar
Default Quick Question: is the '03 Warrior a 4-stroke, or a 2-stroke?
Call me a dumb-***, but is the '03 Warrior a 4-stroke, or 2-stroke?
Old Apr 8, 2005 | 10:22 PM
VelociRaptor350's Avatar
4 stroke
Old Apr 8, 2005 | 10:26 PM
86LT250RFatty's Avatar
[img]i/expressions/face-icon-small-shocked.gif[/img] 4-Stroke!
Old Apr 8, 2005 | 10:36 PM
2phast4u's Avatar
FOUR!!!! here ill do us all a favor
2003 Warrior
Bore x Stroke
83 x 64.5mm
Carburetion
Mikuni 36mm
Compression Ratio
9.2:1
Drive Train
2WD; Sealed O-Ring Chain
Ignition
DC - CDI
Starting System
Electric
Transmission
6-Speed Manual Clutch w/ Reverse
Type
348cc, 4-Stroke Single, Air Cooled, SOHC
Chassis
2003 Warrior
Brakes/Front
Dual Hydraulic Disc
Brakes/Rear
Hydraulic Disc Hydraulic Disc
Suspension/Front
Independent Double Wishbone, 7.9” w/ 5-way Preload Adjustment
Suspension/Rear
Swing Arm, 7.9” w/ Rebound, and 5-way Preload Adjustment
Tires/Front
AT22 x 7-10
Tires/Rear
AT22 x 10-9
Dimensions
2003 Warrior
Dry Weight
397 Lbs.
Fuel Capacity
2.4 Gallons
Ground Clearance
4.9”
L x W x H
72.4” x 42.5” x 42.5”
Seat Height
30.1”
Wheelbase
47.2”
Other
2003 Warrior
Colors
Team Yamaha Blue, Black/Red
Lighting
Dual 30W Multi-reflector Headlights & 21/5W Brake light
Old Apr 8, 2005 | 11:55 PM
jon06's Avatar
its a 4
Old Apr 9, 2005 | 12:00 AM
enFORCER's Avatar
dumb-***.....................
>>>>>>>>>J/K<<<<<<<<<<<[img]i/expressions/face-icon-small-wink.gif[/img]
2many2ride
Sep 27, 2015 04:35 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Rooky
Sep 9, 2015 03:16 AM
