01 Warrior running but not going?
Old Apr 8, 2005 | 10:25 PM
Joesmoe350's Avatar
Default 01 Warrior running but not going?
I have an 01 warrior and the exhaust is making a wierd noise (bogging noise) and it idles find but will only go like 2 mph in each gear. I changed the spark plug but nothing changed about it. Any suggestions?
Old Apr 8, 2005 | 10:28 PM
VelociRaptor350's Avatar
That sounds like the parking brake saftey switch screwing up as usual, it won't let the motor rev with the brake on, and if the switch screws up it will do the same even with the brake off.
Old Apr 8, 2005 | 10:32 PM
Joesmoe350's Avatar
The thing is it worked fine when I went out today then one time i started it up while riding and it just started to make a borring noise as I reved the engine in neutral and gear. So if it was a parking brake is the problem what would I do or is there another problem that might be happening.
Old Apr 8, 2005 | 10:36 PM
Your gonna have to waitr for one of the warrior "techs" to come here to make sure, i know its something about cutting the 2 black wires running to clutch lever and splicing them together.
Old Apr 8, 2005 | 10:39 PM
Joesmoe350's Avatar
ill bring it to a dealership to get maintence and tune up thanks
Old Apr 8, 2005 | 11:01 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
that sounds like that dang gonned flux capasiter bearing on the left drive shaft is acting up agian..
njrider64
Jul 4, 2017 01:40 AM
tpd270
Jul 1, 2015 08:18 AM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
dunc_n
Aug 26, 1999 09:32 PM
