Exhaust leak on the raptor....
Old Apr 8, 2005 | 11:15 PM
Rider1169's Avatar
Default Exhaust leak on the raptor....
It seems that whenever i start up the raptor when its cold (outside temp is 50 and above) it pours out white smoke, i assume oil burning. It has only happened recently, and a while ago i noticed oil leaking up through a bolt in the head, so i take it i must have a rip in the head gaskit, becuase that bolt is as tight as its going. it leaks slowly from that point, and will have to do so until i take it apart and can change the gaskit. The oil burning out of the exhuast im clueless on, unless maybe my rings are bad and oil is slipping buy and going out my exhaust valves and then burning off in the pipe? maybe?
My exhaust leak is where the muffler connects to the midpipe. its tightened real tight around there, but the white smoke still pours from there also. Is there a clamp i can get that will eliminate this exhuast leak? Thanks--Rider1169
Old Apr 8, 2005 | 11:17 PM
garrett5462's Avatar
maybe a patch?
Old Apr 8, 2005 | 11:22 PM
Rider1169's Avatar
I hear bad things about patches. I see those clamps, but im not sure it they make them for quads, they must, but im not sure.
Old Apr 9, 2005 | 01:30 PM
ba01raptoraz's Avatar
I would fix the gasket leak problem first, then move on to the exhaust. But I thought the connection was supposed to be a bit loose to allow for expansion. Once the bike is running on the top end, it will expand a bit. Atleast the expansion thing should be true for the head pipe to midpipe. I'm not sure for the muffler to midpipe.
Bonzhonda300ex
Sep 17, 2015 10:44 AM
bvolks
Sep 13, 2015 12:57 PM
Sep 10, 2015 01:56 AM
Bigtwin700
Sep 9, 2015 09:32 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
