warrior problems leaving me stranded
Stick with the park brake wiring mod you are talking about. It's not overheating!! There is also a ground wire on the right side of the frame up near the fuel tank. Remove it and clean the paint from under it and re-install the bolt.
#17
your avoiding everyones question of "What does the Spark Plug Look Like?" If your not familur(sp) with the different colors or shades a spark plug can be check out this spark plug chart.
If nothing else order yourself a warrior clymer manual, Cause with a 9 year old bike you'll have to work on it from time to time.
I Just remembered, something simular mine used to do was foul the plug alot. I tryed and tryed to rejet it and in the end it was the stator, Apparently it wasnt creating much voltage after it warmed up and it had a real weak spark. Hope that helps.
P.S. Its next to impossible to overheat a warrior, Ive done it once in 9 years.
#18
ok, i have checked the plug to thechart and it looks carbon fouled, it was a new plug but now the whole top is blacxk with carbon build up, and the exhaust tip too!
#19
i wanted to take a look at the stator and i noticed oil is dripping out of the crankcase cover on that side, i yttyhink the oil seal is bad and oil may be seaping onto the stator, could cause my problem you think?
