How much play in blaster crank?
Old Apr 15, 2005 | 12:06 AM
nez02's Avatar
Default How much play in blaster crank?
How much play (left to right) should there be in a stock crank. I just got a blaster, and I am rebuilding the top end and want to make sure the crank is ok.
Thanks
Nez
Old Apr 15, 2005 | 11:29 PM
yamaharider200's Avatar
Im not sure but i would definetely recommend ordering a Clymer manual they have every answer to questions like that
Old Apr 16, 2005 | 12:31 PM
AlkyBurninX's Avatar
Left to right play doesn't matter. A slight amount of up and down play in the rod is WAY to much.
Old Apr 16, 2005 | 09:36 PM
daputz's Avatar
Big end side to side is .4 to .7 mm, up down is .021 to .035 mm. As long as the up down (radial) feels tight do not be to concerned with the radial measurements...........side to side is easily measured with feeler guages.
Old Apr 17, 2005 | 10:03 AM
Hey daputz i like your gas tank. Where did u get it?
Old Apr 18, 2005 | 10:58 AM
nez02's Avatar
I measured the side to side and its about .030 of a gap. How should I measure the up and down (radial). Should I just try to slide the guage in between the bearing and the rod? I felt it and it feels soild no play but I want to measure just to make sure.
Nez
Old Apr 18, 2005 | 05:34 PM
Shav0's Avatar
If there is any noticable play you will feel it by hand..
Old Apr 18, 2005 | 05:35 PM
Shav0's Avatar
Side to side play dosn't matter?[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Apr 18, 2005 | 07:01 PM
JakalWarrior's Avatar
it does matter but the tolerances are alot greater where as with up and down, almost any and its game over.
Old Apr 18, 2005 | 11:09 PM
submakr's Avatar
Yamaha will tell you that any up and down play is a bad thing!!! Failure is right around the corner!!!
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Jackg17
Sep 26, 2015 09:30 PM
