Oil Filter
Old Apr 15, 2005 | 07:15 PM
Chetah's Avatar
Default Oil Filter
Have a simple question hope someone can answer. On my son's Kodiak 400 I just purchased, I want to change engine oil and filter. Someone told me that on these engines you just "clean" the oil filter and reuse. I know on my Honda I always install a new filter at change time. I dont have a manual yet so maybe someone has some experience with this. Thanks
Old Apr 15, 2005 | 08:23 PM
Raptorboy4life's Avatar
Default Oil Filter
Oil filters are expensive.. but for long term riding and u want a safe reliable.. deffinately change the filter every time... every 20 - 25 hours usually.. if you dont have time and you are only riding for a couple hours after a change.. it might be okay but make sure u change it quickly after that.
Using old oilfilters.. some debree (steel , or aluminum shavings from your case/ gears) may be stuck in the filter. if they free up they may infect your tranny , or clutch. and having to deal with replacing a clutch or trans is much more of a hassle than just changing your oil filter!
Old Apr 16, 2005 | 01:24 AM
hondabuster's Avatar
Default Oil Filter
What year is the kodiak? The newer ones have throw away filters, and a screen in the sump which just needs cleaning now and then.
Welcome to the forums
Old Apr 16, 2005 | 05:14 PM
Chetah's Avatar
Default Oil Filter
Its a 1994 Kodiak 400. I have since priced an oil filter and they said $10 which is a bit higher than for my Honda but I think changing each oil change is the safe way to go.
Old Apr 16, 2005 | 08:13 PM
Default Oil Filter
crossover
According to this chart, the fram ch6005, wix24936, and the purolator ml16805 will work as well as the yami filter, and probably be much cheaper.
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
