Is it OK to buy just the left side of a case, even though they are usually matched?
Old 04-26-2005 | 12:55 AM
deltadawg's Avatar
Default Is it OK to buy just the left side of a case, even though they are usually matched?
Just wondering because I cracked my left side and the two halves together will run me close to $500. I can lap both the surfaces if flush surfaces are an issue. My biggest concern would bolt hole alignment. What do you all think...Thanks
Old 04-26-2005 | 01:29 AM
BigScary's Avatar
yes I think you can replace them seperately........if they are split vertically.....but if they are split horizontally you have to buy cases as a match set........
Old 04-26-2005 | 02:16 AM
Turtler's Avatar
Flatness on each half of the cases is an easily machined, drawing callout on the cases and most likely a primary datum for this part. To really find out the answer to your question on whether the cases are interchangeable, it comes down to any matched-machined features between the two halves of the cases. The only way you are going to know this is to call yamaha technical support (if there is any for questions like this?) and get an answer the matched-machining question.
If there is matched machining for the bores, buy a full case and save yourself a bunch of money in the long run.
Let us know the answer if Yamaha gives it to you.
Old 04-26-2005 | 02:11 PM
VelociRaptor350's Avatar
Yeah it should work
mtdewmn
01-19-2017 01:13 PM
SDR-II
09-29-2015 02:06 AM
toonces
07-28-2015 02:58 PM
metal249
07-28-2015 10:35 AM
sublime250
1) Engine problems..
07-11-2015 12:52 PM
