need a quick answer please....YFZ450
Old May 1, 2005 | 12:45 PM
kuz28's Avatar
Default need a quick answer please....YFZ450
how many quarts of oil does the YFZ hold? and what weight Yamalube do you use?
Old May 1, 2005 | 01:30 PM
MTX's Avatar
MTX
Without oil filter replacement
Oil Tank Quantity = 1.55L (1.36 Imp qt, 1.64 US qt)
Crankcase Quantity = 0.20L (0.18 Imp qt, 0.21 US qt)
Total Amount = 1.75L (.154 Imp qt, 1.85 US qt)
With Oil Filter Replacement
Crankcase Quantity = 0.30L (0.26 Imp qt, 0.31 US qt)
Total Amount = 1.85L (1.63 Imp qt, 1.96 US qt)
Oil to use is SAW 5W30 if temps are 0 to 30F degrees, Yamalube 4 10W30 or SAE 10W30 if temps 10 to 95F degrees and Yamalube 4 20W40 or SAE 20W40 if temps are 40 to 120F
Its all the the YFZ manual just to tell you. It shows you how to change the oil, how to drain out of the oil tank, the crankcase, how to change the oil filter etc...
Old May 1, 2005 | 09:30 PM
2fun's Avatar
I'd say that pretty much covers it.
I would however like to add that it seems as though 1.96 qts is still too much even if you change the oil filter.[img]i/expressions/face-icon-small-confused.gif[/img]
Old May 1, 2005 | 09:34 PM
vinny3299's Avatar
yea you can over fill the crank case correct and if you do it'll shoot it back in the tank correct?? or if you put too little in the crank case it'll add more from the tank... correct me if i'm wrong...
Old May 1, 2005 | 09:55 PM
2fun's Avatar
Yes, it all flows as one system, but still, the dipstick has always read a little high whenever I add close to two quarts, even though I am changing the filter too.
I think in the future, I am going to add a little less than what is stated.
Old May 1, 2005 | 10:24 PM
vinny3299's Avatar
hehe yea i noticed i added a little too much and started to squirt at me lol so i drained some out and made sure the dipstick read properly...
shimanok2
Jan 29, 2016 07:37 PM
bvandass
Oct 8, 2015 09:13 AM
YankeeRebel
Oct 6, 2015 06:44 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Rooky
Sep 9, 2015 03:16 AM
