Clutch operation question!
Old Oct 4, 2000 | 02:25 PM
free1steven's Avatar
The Barnett friction plates are wider and you cannot install the rubber cushion rings in between the metal clutch plates. This is causing your problem. I will get the EBC clutch kit because the friction plates are same size as stock. I use three heavy duty springs and three stock. Scuffing your clutch plates may also help. I like to keep as little freeplay at the lever as possible without slippage.
Old Oct 4, 2000 | 06:37 PM
Rob4092's Avatar
OK, so this slippage is normal?
Will it hurt anything or casue the clutch to wear out prematurely?
Should I keep the bike in neutral as much as possible to avoid this movement?
ghost civic
Jan 15, 2020 07:43 AM
Kyle5050
Dec 13, 2019 04:25 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
