Removing Flywheel on Warrior
Old May 2, 2005 | 01:12 PM
Ryeguy's Avatar
Default Removing Flywheel on Warrior
I am trying to replace the starter clutch on my 87 Warrior, I am trying to get the flywheel off. Do you have to remove the 6 allen head bolts that are on a bolt circle in the middle of the flywheel before you can pull it off? The 6 bolts are so tight, I've snapped the allen key trying to loosen them, if I can get the flywheel off without loosening those bolts, I will mill the heads off them, and EDM the bolts out of the holes. So do they need to come out to get it off or what? Thanks
Old May 2, 2005 | 07:55 PM
TRLYFZ450's Avatar
No the 6 allen will stay. What you need is a puller. It will thread into the flywheel then push on the crankshaft.
chingchangchong
Aug 7, 2022 11:36 AM
STLyamwar
Jul 25, 2020 04:44 AM
Jason Richards
Sep 4, 2015 06:17 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
kdg723
Jul 25, 2015 01:20 PM
