Loss of power on my 2004 Kodiak 450 HELP!
Old May 9, 2005 | 02:57 PM
coacho's Avatar
Default Loss of power on my 2004 Kodiak 450 HELP!
I installed 26-9-12s on the front and 26-10-12s on the rear " Mud lites on ITP C Wheels". l love the looks and the feel on the tires, I feel less likely to turn over now but I have 2 problems now. I have loss alot of power and the front tires at times hit my front fender flairs. the shocks are set on the 2nd setting should I crack it to 4 or 5 or just trim the flairs. I don't want to rejet the carb. some people have told me to installing HMF muffler and it will help the low end power loss. I was told to install a REV limiter or a CDI module "I have no clue what this are" Or should I go back to 25-8-12 XL Mudlites and 25-10-12s on the rear.
Any suggestions ???????????????????????????
Sorry about asking so many questions. I'm learning this stuff as I go
Old May 9, 2005 | 03:45 PM
rcnitro's Avatar
i put 25's on mine mudlights and from what local dealer was saying as far as my bike it would loose power if i put bigger tires on i wanted to put 589 on but he claimed i would loose to much power and it would not handle well . all i do know is the ml are alot better than the stocks i had on.lol
places i had to use 4x4 i can go in 2 wheel what a difference. so id say stay with 25. just my opinion.
Old May 9, 2005 | 04:19 PM
CobraR6's Avatar
Thats what I would do, put 25" mud lite XL's on. Make sure you get teh XL's, so you have the deep lugs.
Old May 10, 2005 | 10:57 AM
WindmillAtWork's Avatar
Yeah stay stock size on the Kodiak unless you are planning to mod it. I also would go with the AT version of the mudlites unless you are just going to be mudding. If your trail riding you will get alot less of a tractor like feel from the AT. Personally I would go with the 25" Holeshot ATR Radials. You will get better traction and the best handling for your kodiak.
HoleShot ATR
Old May 10, 2005 | 11:18 AM
Starky's Avatar
Since you already have the 26" tires, buying another set of 25's would be a waste. Tighten your shocks 1 or 2 notches and see how it feels. The easiest way to gain power is to put on a new pipe, modify your airbox and re-jet. An HMF pipe is very good but it's also VERY loud. If you want to stay close to stock Db's, the HMF QS1 is supposed to be a good choice. You can also change your clutch but I don't know much about that.
Old May 10, 2005 | 12:17 PM
CobraR6's Avatar
Try burning 1 inch of tread off. That way you have 25" tires. [img]i/expressions/face-icon-small-wink.gif[/img]
Old May 10, 2005 | 12:31 PM
coacho's Avatar
would changing only the pipe help
Old May 10, 2005 | 12:36 PM
MrDumass's Avatar
Super Quad Patrol
Athens Archery Field Staff
Best lunch hour ever!
Since you already have the 26's I would say do what it takes to get them to fit right. If it takes to cut the fenders a little or adjust the shocks, maybe put a lift kit on it?? I would definetly get a pipe/filter and rejet it to help. The cdi is like the computer I believe it lets it rev higher. The mods I did to my BigBear really improved the low end grunt, and helped with pull throughout the gears. Looking at mud-lites now. I just noticed air box vents on a website. I'am going to have to look into those a little more, they may add more air flow and alow me to jet up one more size, and gain more power![img]i/expressions/face-icon-small-happy.gif[/img]
Old May 10, 2005 | 12:40 PM
MrDumass's Avatar
Super Quad Patrol
Very little. You need to open the air flow into the motor, and then back out through the pipe. You will have to re-jet. Letting more air in and out requires more gas to get the best gains, not to mention keeping your motor from running to lean.
Old May 10, 2005 | 03:06 PM
coacho's Avatar
will just a new pipe help
