Combo on wolverine
I'm still deciding on what tires to get. I think I want the Outlaw 26x10x12's for the rear and Titan 589 25x8x12's for the front. I was leaning towards Titans all around (with 25x10x12 rears)but the Outlaw is a little taller and has better tread. Whaddya think?
First of all, don't mix tire heights from front to back. This will have your front and back running at different ratios...not good. Either run 26" or 25" all the way around. I wouldn't run over a 25" tire. The wolverine is just geared too high. By putting taller tires on it you are doing the same thing as raising the gear ratio.
I have a 95 Wolverine with 25 inch Sur Tracs on it and I find these tires to be the best all around tire for this quad. There great in the mud and still good on all other kinds of terrain.One thing I found is to stick with the stock widths 25-10-12 rear and 25-8-12's front, I've seen my buddies go with the same size Blackwaters on all four corners and they have trouble turning them in the thick stuff. I also have added a DG pipe to compensate for the larger tires and also a Jet kit. One lesson I learned the hard way was not to buy an alloy pipe again, it has cost me more to have it welded then it is worth.If your thinking of an after market pipe look for a steel one .
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
