Raptor Air Box..
Old May 15, 2005 | 11:41 PM
yamahaandchevysgeterdun's Avatar
Default Raptor Air Box..
i've heard of taking the cap off, drilling holes in the top of the cap, or buying a bigger box to get some more power...Whats the real deal? Or maybe just buy a K&N?
Old May 16, 2005 | 10:56 AM
DRoCk's Avatar
Well the basic idea is to get more air into the engine. More air+more fuel=more power... then with more air going into the engine you need to get more air out, thats why most of the time when people are getting exhaust systems they also remove the air box lid, or drill holes in it. Basically i would guess that the determining factor for leaving the lid on or drilling holes in it is what kind of terrain you ride in. Taking the lid off is going to get your filter dirty faster, so just drilling holes in it will help a little, as well as get a little better air flow. I am going to leave my lid on even with a filter that doesn't require the lid to hold the filter in just to keep it cleaner. Hope that helps
Old May 16, 2005 | 11:54 PM
Lostsoul's Avatar
With no lid, you'll want to stay out of the water.
Old May 17, 2005 | 12:39 AM
PolishCowboyPL's Avatar
Don't forget your going to have to rejet your carbs after this, becuase you increase the air, but leave the fuel the same so therefore run lean... Not good for the engine, lean mixture means hotter temperatures, you can damage stuff.
MIke.
Old May 17, 2005 | 10:09 AM
Warrior02man's Avatar
MIke.
to be more specific.. burn holes in ur piston.
Old May 17, 2005 | 10:42 AM
BigDylan's Avatar
I run a pro-flow kit with a K&N w/outerwear
i run no airbox lid but i do run an outerwear airbox cover
it keeps the airbox clean a lot better than i thought it would
Old May 17, 2005 | 10:56 AM
HoundDog06's Avatar
You might want to consider the EHS Racing lid kit. It allows you to get the same airflow as no lid while having the dirt protection of having a lid. Don't confuse this lid with filtered lids which drastically reduce airflow when used with a filter in the stock position. We now run these lids on every bike we own (including a 686 Rap, 2 grizzlies, a KFX400, and a V-Force).
~HoundDog
bmxatv10
Oct 14, 2022 06:23 PM
Joe454
Nov 20, 2020 01:19 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
