Weird starting problem
Old May 28, 2005 | 03:21 PM
SmokieDaBear's Avatar
Default Weird starting problem
I just finish riding my '02 Raptor & I turned it off in my front yard. 2 minutes later I was gonna move it & notice the bike won't start. No (N) light..No sounds @ all. The key is in, turned on..Gas is on. I'm getting no sort of power. I'm hoping it's the battery as I haven't ridden the quad in about 2 months prior today. Any suggestions on what to check?
Old May 28, 2005 | 04:27 PM
mmmbeefy's Avatar
I've heard of the wire harness thingy that is located under the back seat coming loose and causing a loss of power all the way around. To lose the "neutral" light, your battery would have to be GONE, or a connection has come loose. My guess is a connection...
Old May 28, 2005 | 05:39 PM
I'll check my connections. Thanks
Old May 28, 2005 | 05:59 PM
mmmbeefy's Avatar
It would be a sweet irony if it were the battery connection! That would be one helluva cross country diagnostic!!!!
Besides, it would be really easy to fix for you to!
Old May 28, 2005 | 06:25 PM
hondabuster's Avatar
If it isnt a fuse, or loose connection, check the battery with a voltmeter. Batteries can and do fail suddenly like that.
Old May 29, 2005 | 12:38 AM
warriorboy22's Avatar
same thing happened to me i turned off the quad then went to turn it back on and dint even have a neutral light it ended up being my battery.
Old May 29, 2005 | 02:23 AM
UltimateAussie's Avatar
try bump starting it if it starts its you battery. if it doesnt than its not the battery
Old May 29, 2005 | 08:07 AM
As all you guys know, the Raptor is a big pretty heavy fellow, so bump starting is out for me especially by myself. I'm going to get the battery charged today. Hopefully all goes well.
Old May 29, 2005 | 11:45 AM
Well I put my battery to charge & within 30 seconds, it's telling me it's fully charged. Anyway, I went ahead & tried it & it started my Raptor. So I guess I'm back riding again. I guess it's time to change the battery. Anybody know of any cheap online stores that have batterys for the Raptor?
Old May 29, 2005 | 12:38 PM
Before you toss that battery, pull it out and have it load tested. Most every auto parts store will do this for free. Thats the definitive answer, to whether the battery is junk or not. You could have had a loose or corrorded cable, and now that its been tightened, its all good.
30 seconds seems like an awfully quick charge, which makes me think the battery is still good, and the problem was a connection.
