K&N vs modded lid
Old May 29, 2005 | 12:05 AM
yamaharaptor350's Avatar
Default K&N vs modded lid
What would allow for more airflow... a K&N powerlid or just straight holes in the air box lid... i hear that keepin the snorkel on your airbox lid equalls more air flow because the snorkel makes a sucshin in your intake makin more airflow... is that true or would the power lid allow for more air???
Old May 29, 2005 | 12:08 AM
yellowrider250ex's Avatar
i like my k&n airbox lid better than the holes allover your airbox
Old May 29, 2005 | 01:28 AM
hondabuster's Avatar
Id think it would get down to square inches of available air. Adding more holes makes more area available for air to flow. If you remove the lid or the lid and box, itll flow the maximum, that the filter will allow.
Old May 29, 2005 | 02:19 AM
UltimateAussie's Avatar
i dont know if anyone has used them but uni makes some little filter plugs that you put in holes that are i your airbox so its kind of like a bunch of little power lids
Old May 29, 2005 | 11:50 AM
NastyNate03's Avatar
i saw those UltimateAussie i would save the money for somethingh else then the power lid i would drill holes and spend the money for something else for performance
Old May 29, 2005 | 11:59 AM
warriorboy22's Avatar
i have air box vents and they work fine they keep the dirt out and still let in more air
Old May 29, 2005 | 03:18 PM
spudley's Avatar
I had a pretty good debate over the same thing raptor350, I choose the powerlid and was surprised to see the kit came with a jet kit. It actually will need to be re-jetted, so I think it does flow quite a bit more air, If you do get the powerlid order in a crank case breather vent for some reason or another the kit doesn't include one. Oh yeah if you get the kit maybe let me know if or how your able to stick the outerware on the lid.
Old May 30, 2005 | 12:29 AM
thatnx for the replies guys... what is a crank case breather vent and where is it located... would i have to get that is i only drill holes in the lid?? thanx
Old May 30, 2005 | 12:48 AM
spudley's Avatar
No you would'nt need the c-case breather vent filter if you drill holes in the lid. I looked at those uni filter plugs and it was my understanding that they are not washable, So every once in a while you have to pop them out and replace them. They are not really expensive but if your like me finding lots of mud and water it could be. For me its the powerlid.
Old May 30, 2005 | 01:15 AM
450mxer's Avatar
hello
