Backfiring Banshee
Old May 30, 2005 | 11:42 AM
jes2181's Avatar
Default Backfiring Banshee
I have a 95 shee it has not run in a couple of years. I got it running it idles fine. At about 1/8 to1/4 throttle it starts to backfire and pop. Could it be a piston , stuck ring or a cylinder? I checked the reeds ,is it common for the reed not to lay perfectly flat? There a small gap maybe a couple mm. Could it be to rich or something in the carbs? HELP!!!!
Old May 30, 2005 | 11:58 AM
bansheeripper's Avatar
If it sat for a couple years and you didnt treat the gas, or drain it, I would guess your carbs are all gunked up. Probably will have to take the carbs apart and clean them .
Old May 30, 2005 | 01:14 PM
jes2181's Avatar
I did clean the carbs. It was running the same way before.
Old May 30, 2005 | 09:07 PM
lapeerbanshee's Avatar
you might have a fouled plug if you didnt already check.
Old May 30, 2005 | 09:45 PM
jes2181's Avatar
It's got new plugs. Would a hotter plug help?
Old May 31, 2005 | 12:46 AM
rotty150's Avatar
jets,pilots arn't plugged?floats working ok? air filter clean? any mods done to it before you rode it last? new gas?
Old May 31, 2005 | 10:51 AM
daputz's Avatar
I think you nailed it on the head with the description of the reeds. They should lay flat in the reed cage. Sometimes they can be flipped over and flatten out..........otherwise they should be replaced.
ReconBayou
Oct 31, 2022 05:37 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
Brandon400
Sep 7, 2015 12:20 PM
