DO I run the risk of hurting my engine if not rejetted?
I'm not denying it isnt running lean. I know it's running lean. I'm saying that I see that by it not idling correctly. I was just asking if it will do damage, obviously it will. How much $ are we talking for a new piston to be put in if something goes wrong with it. I just need to run it this weekend, then I'm taking it to the shop to get it jetted.
#15
prolly bout 200 depending on if you damage the head any too. A jet only costs about 2 or 3 dollars and most dealers carry them. If you cant get one then you can have a machine shop or something drill out the one you have a bit to get you on the rich side so your fouling plugs instead of melting.
#16
#18
#19
#20
Besides, I called 2 Yamaha technicians at highly rated Yamaha dealers in the Ohio area and both said the risk is extremely minimal if I'm just running it on the weekend as long as I get it worked on next week. There's plenty of 15 year olds on this site giving advice that isnt exactly highly regarded. Besides, tell me who has ACTUALLY burned up a piston with the setup I have - stock everything with an FMF pipe.
