cant find the little squeek on my raptor
Common problem, undo the upper rear shock bolt and remove, move shock out of locator on frame and grease or anti sieze the ball joint inside the shock itself were the bolt goes through. Make sure the ball can swivel freely then reinstall, should be ok now!!
I HAVE NO 660 BUT I HAD THE SAME PROBLEM SO I GOT SICK OF IT TOOK OUT THE SWING ARM BOLT LUBED EVERY THING UP GRESSED ALL LIL ZERKS STILL freaking squeaked finally figured out it was the back shock were it mounts on top so try spraying WD-40 were your rear shock mountS on top I bet cha its it let me know.
Originally posted by: Jibrille
I usually pressure wash the crap out of my suspension to avoid squeeking.
