Bent frame or A-arms?
Old Jun 19, 2005 | 04:01 PM
YamahaRyder4Lyfe's Avatar
Default Bent frame or A-arms?
Well, i had a little accident last night...well, maybe not so little. But anyways, the quad flipped end over end atleast twice in mid air, then slammed into the ground which in turn, popped the bead on my front right tire, popped the spark plug cap off, smashed my little stock front bumper, and either bent the right a-arm (when your sitting on the quad) or the frame, and all this happened beasue the back end kicked up from going over a huge indent in the trail. i beleive that its the lower right a-arm, becasue the right wheel is now at an angle like this / (also when your sitting on the quad, but not that much of an angle). and the wheels are also uneven when you look at them from the side, like the front right a-arms are moved back a little bit. My dad on the other hand, beleives that i bent the frame and my a-arms a little bit. I think that the a-arms would bend waay before my frame did, but i just want to know your opinions on what is bent. Thanks
Old Jun 20, 2005 | 02:37 AM
Swansonator's Avatar
Well I have two bent raptor frames. The first one bent making the wheels offset, when measuring from the foot pegs one wheel was further ahead of the other. Best way to tell is, with the full engine skid plate. If the front frame clamp doesnt line up properly then more than likely the frame is bent. You also might want to check the ball joints and the spindles to make sure they are not bent. I also bent a lower ball joint when the frame got bent.
Old Jun 20, 2005 | 01:27 PM
fakesnowsucks's Avatar
your lucky u didnt hurt urself i just did basically the same thing 2 months ago. hit a mound when i hydroplained in a ditch goin like 45mph back tires kicked up and sent me flying and broke a vertebret, im in a back brace for 3 months and cant ride for another 3 after i get it off. no damage to the raptor tho good luck with urs sorry to hear man!
Old Jun 20, 2005 | 02:08 PM
TheRaptorMan's Avatar
When I rolled mine off Delbarton it bent the a-arms and the frame where the lower a-arms connect. May want to give it a good look there. Once you get the plastics and a-arms out of the way you should be able to tell where the bend is at. Also look for cracks in the paint its a good way to tell where the bends are at.
Good luck.
Mike
Old Jun 20, 2005 | 03:47 PM
yeah...thanks for all the replys, right now i havn't looked at it to much though. It still drives alright, except the front brakes are messed up pretty bad, you pull them and it pulls to the left, or the left tire locks up and the right doesn't. We took the tired off and looked at the brakes, bled them again. When you pull them, you can here clicking in their. I didn't look at it to closely though, its just been sitting there in the garage for the past couple of days. Ive been busy working on a 197? suzuki bike. Just to get away from the fourwheeler for a while. I think ill take a better look at it tonight, with the plastic off and ill get the ol` tapemeasure out and start measuring. Thanks for all your help
Old Jun 22, 2005 | 05:23 PM
Boosh71's Avatar
I have a similar problem, I think that the frame is ok, but if the frame is bent, then what is the best course of action to fix it? Do you have to get a new frame, or have ti straightened?
Old Jun 22, 2005 | 09:11 PM
depends on how bad its bent, if its bent a little bit, you mihg tbe able to straighten it. But if its bet pretty bad, you can probably fix it but its probably reccomended to get a new, but its up to
Valder
Nov 28, 2020 07:38 AM
EIF
Apr 20, 2017 07:15 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
Albertaboyy
Sep 9, 2015 09:51 AM
meddy0388
Sep 9, 2015 06:41 AM
