Warrior jetting
Old Jun 26, 2005 | 07:03 PM
jaslv's Avatar
Default Warrior jetting
Bought a 99 Warrior about a month ago. The guy said the top end had been freshened up with a new piston and rings 10 over and added a little compression. I just added a DG pipe (I know not the best choice) Do I need to look at jetting the carb? If I do I think I'll just order a power up kit with a filter and jets. What is the stock jetting and what size jets will I need for the changes?
jaslv
Old Jun 26, 2005 | 09:54 PM
yamaharaptor350's Avatar
yea your gonna need to jet the quad... get the power up kit. If u get a jet kit it comes with a ton of different sizes and u just choose which size will work the best with your quad... i have a 136 dyno jet in mine for the main. It all depends on your bike too some will just run on fatter or leaner jets than the exact same bike. It will also depend on your elevation and temperature. If u dont jet it your runnin it really lean and that can blow a motor. not shure about the stock jet sizes tho
ReconBayou
Oct 31, 2022 05:37 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
