warrior hp speed
Old Jun 30, 2005 | 12:21 AM
albayfz's Avatar
Default warrior hp speed
speedped why would u only top it in 5th dont u no u have another gear and there is no way in the world u got that thing going 75 a raptor can just touch that u got problems man. hahahahahahahahahahahahaha god ur funny
Old Jun 30, 2005 | 12:25 AM
2FAST4URASS's Avatar
And by the way SPED my man take it easy there just saying it aint happening I mean 75 is a pretty big number for a atv I mean the biggest of atv's say the (660R just is) capable of hitting that some probally wont with a larger rider. And if your freind has went to swapping his tires then yea his spedo is off diffrent size tires will!!! screw with ur spedo for example i have a mustang GT it had 225/70/16 on it i went down too 225/50/16 my spedo is off by 6 miles per hour now due to that change and how do i know you ask because my freind lives in front of a cop and i got him to clock me.
speedped79's Avatar
hey maybe becuz its geared tall and it wasnt reved out in 5th it wont really go any faster i hav to drop down in gearing also ive fixed all the bugs such as knocking turned out to be too low octain i have to run on 95 not 91
Old Jun 30, 2005 | 12:27 AM
And this is what i get trying to be nice to a fellow 350 owner TISK TISK.
Old Jun 30, 2005 | 12:33 AM
  #15
holeshotz8436's Avatar
this whole thred sounds weird and speedpeds info sounds way off but it makes absoutly no sense that you would have to run 95 octane in a warrior has no engine mods and this would make the knocking go away. do you have a hi compression pistion and not know about it or sumthing?
  #16
albayfz's Avatar
man i gust wanna here u say u toped out in 6th not 5th because if u dident no u had that extra gear u should be able to hit 80.....
Old Jun 30, 2005 | 12:38 AM
  #17
speedped79's Avatar
ok let me set this whole thing straight i hit 75 in 6th not 5th i got the gears mixed up i started off in 2nd also the motor is not stock i just got off the phone with the previous owner he said it was bored 30 over stage 1 cam hp piston and rod and he said always run 95
Old Jun 30, 2005 | 12:53 AM
  #18
also i dont think my warrior is stock im pretty sure the orig owner did the motor as well ill have to find out also rapter 350s suck horibly
And the only thing that sucks is your spelling bro (raptor not raptEr and horribly) not horibly there was no reason for you to get all pis Sy I WAS being nice I could have been a lil bish like you and just speak what i though when i read your post so here better late than never 1st off your sh it is not going to go 75 on any day that is if you even have a atv even with a cam and bored 30 over it still isnt going to sooooo why dont cha get tha he!! out of here we allready have enuff bull shi ttaz in here we need no more.
BEST OF WISHES
JEREMY [img]i/expressions/face-icon-small-wink.gif[/img]
Old Jun 30, 2005 | 12:57 AM
  #19
that sounds about right.........the pistion is probally 11:1 so you could probally get away with 93 or 94 and you should notice a slight power increase now that you have the right octane gas in there.....what is the warriors stock gearing setup because i know that if i dropped 2 teeth on my lakota(i already went up 2 in front) i could hit around 73 with 20 inch tires and a little bit higher then that with 22's and i have pritty much the same mods but you got 50 more cc's so you will have more pulling power.........i'd say 73-75 is possible on his warrior if the gearing is setup the way i think it is(add 2 up front, drop 2 in the back)
Old Jun 30, 2005 | 09:40 AM
  #20
2phast4u's Avatar
do u no that .030 over isnt even bored out to 360cc's its lik 352cc becuz .040 is 357cc stage one cam effects bottom end not top end HP piston is lik 10.25:1 or 10.50:1 at most and even w/ your 15/40 gearing i dont see u being able to pull 75 u would hit the rev limiter in lik bottom of 5th
maybe it was his powerband?????
