shee firing order
I think you guys missed the point of his question. I think he knows the plugs fire at the same time.. I think hes asking if you can get a crank and will have both pistons moving the same direction at the same time. IE: both go up then both go down(don't some harley's work like that?) As opposed to one piston fireing while the other draws in.. Sorry if i confused anything but that's what it sounds like to me.
Blue 2000 Kodiak Ultramatic 4X4
What did the experts say? Just kidding. Why would you want a Banshee with both pistons moving in the same direction at the same time? It would run like crap. One piston goes up, one piston goes down. Both plugs fire at the same time, so each plug is firing twice per power stroke. Just easier to make it that way.
because If both pistons were moving on the same stroke it would change your powerband. I don't know if you would get more low end torque or more high end but it does change your powerband signifigantly. It would sound like a 2 stroke harley
heh..
heh..
IMLN
Sep 28, 2015 03:32 PM
Elkaholic
Sep 6, 2015 02:44 PM
