yfz450 drag ready
Old Jul 21, 2005 | 10:53 AM
BigScary's Avatar
Default yfz450 drag ready
Originally posted by: keelam
what should i do to make my bone stock 2005 yfz450 drag race ready? i wanna make it the fastest out there/ even woop the banshee!! i dont care bout cash, as long as it makes it the #1!! thanks....
you will never be the fastest out there on a yfz...........unless you are in your garage.............
buy a shee and call one of the MANY good builders out there...........
you can make a yfz fast..........just not near the fastest...........my yfz is fast...........just won't hold a candle to my shee............
Old Oct 26, 2005 | 08:23 PM
MarkFiddling's Avatar
Do they make yfz450 drag frames? And, fakesnowsucks, where do you go riding?
Old Oct 26, 2005 | 09:39 PM
Gills04yfz's Avatar
first off get the 523cc big bore stroker kit which is the biggest u can get i believe, hotcams, full exhaust system, aftermoarket CDI box, high comp. piston, valves valve springs, lower it, rejet k&n airfilter, and thats all i can think of, heres the link for the big bore kit
http://www.maxpower-engines.com/atv-bb-bolton.htm
Old Oct 27, 2005 | 01:36 AM
686raptor's Avatar
i think pakard has a couple of 535 yfz running around. not sure of the company but there is a billet cylinder out for them and you can get them in a couple different colors or polished. we are looking into one for our yfz. later
Old Oct 27, 2005 | 01:11 PM
  #15
fakesnowsucks's Avatar
i ride alot of county road ditches i live in anoka so not much riding around here. i have a couple buddies with some land and we go out to aransaw wisconson and wheeler wisconson every once in awhile
Old Oct 27, 2005 | 06:09 PM
  #16
O. I see. How far is Anoka from Lakeville? Maybe we can go riding sometime. My freind has land also.
Old Oct 27, 2005 | 06:24 PM
  #17
choosetolose04's Avatar
Ditto. Call CP Customs afterwards and he can fix you up with the drag frame or even modify your stock frame into a drag frame and nitrous aswell. You should gain atleast 10-15 bikes over stock. It also depends on what kind of drag racing you will be doing...either hillshooting or flat drags. If your hillshooting, you might want to call KMS for a turbo and if your wanting to run flat drags then the above setup should make you quite competitive. [img]i/expressions/face-icon-small-wink.gif[/img]
franklyme
Oct 21, 2016 07:18 PM
Sep 23, 2015 06:23 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
