blaster mods
Old Aug 5, 2005 | 03:32 PM
Boombotz's Avatar
Default blaster mods
yo guys i wanna put some parts on my 01 blaster but i dont wanna spend alot of money....wut parts should i put on and how much will they cost? I was thinkin a pipe n a filter
Old Aug 5, 2005 | 03:34 PM
YFZ660R's Avatar
To ATV Thieves: "Hope you guys flip and die douches!"
A good pipe along with a K&N, re-jet your carb and you may also want to try better reeds.
Old Aug 5, 2005 | 03:37 PM
Boombotz's Avatar
whe u re-jet ur carb ur puttin a wider fuel injector therefore doesnt that cost mad money?
Old Aug 5, 2005 | 03:41 PM
Speeddemon73's Avatar
Carb = Carbeurator
Injector = Fuel injection
You have either one or the other, but you can't have both. If your talking about re-jetting then you a carb and kit with several differnet size jets will run you around $40.
Old Aug 5, 2005 | 03:43 PM
TheTurtle's Avatar
no you just change the pilot jet and maybe the needle. and i would go with a foam filter over the k&n
Old Aug 5, 2005 | 03:47 PM
YFZ660R's Avatar
No, your quad is not fuel injected. Your quad has a carburator, it's not expensive at all. You may have to change your main jet that you could get for about $10 at you local dealer and do the work yourself. And as for the air filters, foam for muddy riders, K&N for sandy conditions.
Ahtatu
Sep 28, 2015 12:14 PM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1ArmBandit
Sep 8, 2015 08:59 PM
