Raptor Oil Tank
Old Aug 6, 2005 | 07:17 AM
raptorgav's Avatar
Default Raptor Oil Tank
My buddy was doing an oil change on his 660 raptor last night and when he went to undo the drain plug he tore the fitting out of the bottom of the tank. Which after market tank should we buy and from who. We would need it shipped to australia. BTW a new OEM is x japan and about 3 weeks away.
Old Aug 6, 2005 | 01:14 PM
Raptor149's Avatar
I did the same thing. The fitting cracked and separated from the tank and was just spinning. Couldn't get the bolt out. I just took the tank out and had the drain neck welded back onto the tank. A lot cheaper than spending $300.00 on a new tank. If you do go aftermarket, UM is a good tank to buy.
Old Aug 6, 2005 | 04:29 PM
YFZ660R's Avatar
To ATV Thieves: "Hope you guys flip and die douches!"
Wow, I thought this had only happend to me! I too couldn't get the bolt out! I just had it weld for $10.
bmxatv10
Oct 14, 2022 06:23 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
