Raptor probs
Old Oct 18, 2000 | 11:20 AM
REDDOG1233's Avatar
Anyone out there have a warped rear brake rotor on their Raptor?
Old Oct 18, 2000 | 12:30 PM
wyz's Avatar
wyz
Yeah Reddog- I was lubing my chain up and noticed
that right away. I have only been out twice and have not been abusive. I think it came that way
and will be checking with my dealer.
Old Oct 18, 2000 | 12:37 PM
garyc660R's Avatar
If you bent it yourself while riding your dealer still should cover this problem under warranty. That should have to be covered indefinately considering that the skid is plastic! It's a wonder I have'nt bent mine. Wait a minute...mine is squeaking. I'll have to check it when I get home.
Old Oct 18, 2000 | 12:38 PM
badchad's Avatar
Reddog, no probs with brake rotors, but I did have a chain derailment problem. I took my raptor to the track and could not even go 1 lap without throwing the chain. I had checked everything that I could think of that may have been causing that to happen, but found nothing wrong. The dealer replaced both sprockets, and I haven't had a chance to ride it yet cause I'm working offshore. If my quad continues to have this prob, it's gone!
Hopefully it was only a warped or bent sprocket, cause I really like the quad, but if I can't ride it on the track, I don't want it!
Old Oct 18, 2000 | 12:43 PM
garyc660R's Avatar
When I adjust my chain for about an inch to inch and a half slack and push down on the rear the chain seems to get kinda tight quick. Chad..I wonder if your chain is too tight when the suspension is at the end of it's travel.
Old Oct 18, 2000 | 03:33 PM
bshiels's Avatar
Reddog123 and WYZ- Should have bought a Honda...Ha Ha. Just kidding. Looking forward to the ride at Little Sahara next weekend (27-29th). Anyone else out there wanting to meet, drop any of us a line.
Old Oct 18, 2000 | 04:58 PM
sandaddict's Avatar
Speaking of chain tightness. Do you measure tightness by picking a spot on the chain,say the top,and push down all the way measure at top,then pull up and measure to the top. Or do you push chain down measure at bottom, pull up and measure to top. Owners manual insn't clear.
Old Oct 18, 2000 | 05:41 PM
paulb's Avatar
hi sandaddict
chain adjustment -- in the middle between rear sprocket and swing-arm chain slider you push down and measure the bottom of the chain then push up and measure the top af the chain.
paul
Old Oct 18, 2000 | 06:24 PM
ccarpe1's Avatar
I have got a warped rotor also. Of course I have had two bent axles...I do not get why I am having so much trouble with my.....(go ahead)...rear end. I also have problems with my chain coming off ad am always tightening it.
Old Oct 18, 2000 | 08:36 PM
YaMaRaPtoR's Avatar
the Problem with your rear end appears to be too many vegetables, The raptor is a meat eater you know. Check the alignement marks on the housing make sure they are even and tighten it down. If not its probably a bent sprocket.
