Banshee Bot
Old Aug 15, 2005 | 12:12 AM
lt230s4life's Avatar
Default Banshee Bot
What kind of mods can i do to make my dads banshee better for climbing silthills. so i need low-end. The only thing i have is 12T sproket toomey t-6's, sur-trak tires in back, cool-heads. so how can i make it a silthill-eating machine? or just better.
Old Aug 15, 2005 | 11:21 AM
RDZ350's Avatar
Default Banshee Bot
Believe it or not,porting can help.I'm not alking about an all-out drag porting of course.My banshee was easier to ride around on after I had it ported.I'm not saying it's a trail quad,but it help the mid-range quite a bit.Might try it.
Old Aug 15, 2005 | 02:01 PM
midnite's Avatar
Default Banshee Bot
T-6 doesn't make much more power with porting, as it was designed to make the most power with stock cylinders, while t-5 responds very well to porting {if you doubt this look at the forums at banshee hq.com}. A pro flow filter+billet adaptor will do wonders (when I put one on my 87, I went from a 280 main jet to a 320 mj mikuni}. Thats 4 sizes bigger and it had alot more top end power with my T-3's. If you want all the top end power you can get try some shearers or rocket in-frame pipes.
Old Aug 15, 2005 | 07:00 PM
98bansh's Avatar
Default Banshee Bot
[img]i/expressions/face-icon-small-shocked.gif[/img] 12 tooth Damn thats a hella lot of shifting
Old Aug 15, 2005 | 08:12 PM
Default Banshee Bot
its not all that bad
i looked at t-5's but it came wit t-6's
Old Aug 15, 2005 | 08:19 PM
enFORCER's Avatar
Default Banshee Bot
If you want low end power, then get a 2 into 1 pipe........
Old Aug 15, 2005 | 08:22 PM
trailrider500's Avatar
Default Banshee Bot
If you want low end power with a great all around power band, talk to Bubba, he will get you going in the right direction.
TR
Old Aug 15, 2005 | 10:09 PM
RDZ350's Avatar
Default Banshee Bot
Midnite is right.I've tried both the T-6 and T-5.The T-5 is the best of the 2 as far as I'm concerned.Especially when it comes to adding modifications.I've never tried the 2 into 1 pipe.Might be worth looking into.I raced against one before in the 300ft.It was impressive.Not sure what all he had done to it.It would run though.
Old Aug 15, 2005 | 11:41 PM
Default Banshee Bot
where can i find the 2 into 1 at and does any one have any pics of what it looks like.
Old Aug 16, 2005 | 12:13 AM
RDZ350's Avatar
Default Banshee Bot
I think the name of the company that makes it is DYNOPORT.Might try dynoport racing.com or something like that.I'm not really sure what the name of the site is.Hope this helps.
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
