THIS IS BS
Old Sep 7, 2005 | 06:57 PM
AustinONeal's Avatar
Default THIS IS BS
i have ordered 3 different time's ITP holeshots and everytime i get them i have to put different amounts of air in them to get them to balance out right even thought it was my axle tried them on a different bike same results. why are they doing it i have to put like 25 in one and 5 in the other to make them set level
Old Sep 7, 2005 | 07:26 PM
HooPharted's Avatar
Default THIS IS BS
are you making sure the tire is "popping" onto the second bead on all of the tires/rims ? you have to over inflate (and try some dishwashing liquid around the bead) the tire to get it over the "second bead" on the rim,,,also rapping the tire with a hammer HANDLE,while it is over inflated helps it pop over the second bead,along with the DW liquid
inspect both sides,all the way around the rim where the tire meets,,,not for sure if this is your problem,but just a thought
Old Sep 7, 2005 | 07:56 PM
86LT250RFatty's Avatar
Default THIS IS BS
I have 4psi in both my Holeshot XCR's on stock rims, and they are level and everything..
Old Sep 7, 2005 | 10:17 PM
Default THIS IS BS
must be nice
Old Sep 8, 2005 | 01:35 PM
caliraptor's Avatar
Default THIS IS BS
you have the worst luck austin
Old Sep 8, 2005 | 03:50 PM
Default THIS IS BS
seems that way, cant get right
Old Sep 8, 2005 | 06:14 PM
bl4cksh337's Avatar
Default THIS IS BS
besides the point we are clear that i am the original black sheep right??
Old Sep 9, 2005 | 03:23 AM
Default THIS IS BS
the origanl black sheep is Greg "Pappy" Boyington
In WW2 Marine Coprs. Major Greg "Pappy" Boyington commanded a squadron of fighter pilots. They were a collection on misfits and screwballs who became the terror of the south pacific ,They were known as the BLACK SHEEP
of course you already knew that.....
