Mechanically inclined
Old Sep 14, 2005 | 11:47 PM
YFZ450Hornet's Avatar
Default Mechanically inclined
With the gas smell still in the oil and reading the posts on the topic about the smelly oil i was wondering what it would cost to get the top end replaced and the shop goes about 50 an hour and if worse comes to worse....what would it cost to have a new piston put in? I would love to do this myself but I just don't have the means so having someone else do it is the only way to go. So if anyone has an idea please let me know
Old Sep 15, 2005 | 12:48 AM
Nikates's Avatar
my buddy paid around $800 and had high compresion wisco piston put in his
Old Sep 15, 2005 | 12:49 AM
midnite's Avatar
Is your 05-yfz the bike with gas in the oil? Seems alittle soon to put a top end in it. Either way first make sure your carb vent tube isn' t blocked. If it is gas will run into the motor, instead of dripping out the vent. If you need to have if rebuilt, just the top end is going to cost around $500 to $750 dollars for parts and labor. $50 a hour seems excessive.
Old Sep 15, 2005 | 01:00 PM
quicksilver's Avatar
u mean there's gas in the oil? a worn upper end wont really cause that. Gas in the oil will CAUSE a worn upper end, maybe that's what you mean.
anyways, i would find the problem first. a shop will put a new upper end on, but if you have a carb problem letting gas run into the oil when the machine is shut off, you'll wreck all that work right away. My first guess is the needle-and-seat valve that the float turns on and off is sticking open, letting the gas overflow into the intake, runs into the cylinder and down into the crankcase. also a float level too high would do that, and a saturated float will sink in the fuel and open the valve. it could be any of these. I would fix this problem first, and then worry about the upper end.
Old Sep 15, 2005 | 02:00 PM
Would this flood with the engine on??? I always shut off my fuel and let it run untill it dies...would the vent tube cause this when engine is running or shut off? Please let me know if you know
Old Sep 15, 2005 | 02:07 PM
quad2xtreme's Avatar
depending on what you mean by a top-end rebuild, you are looking at about $50 for rings, $40 for a gasket kit, and 3 hrs of labor assuming you take it to the shop powerwashed, degreased, and take the plastic off to the point the mechanic has easy access. $50 for engine labor is the going rate around the Baltimore area.
Boring the cylinder will run about $50 plus the cost of the new piston & rings that will come as a set. The labor will still be about 3 hrs.
/Jon
Old Sep 15, 2005 | 11:57 PM
Would this flood with the engine on??? I always shut off my fuel and let it run untill it dies...would the vent tube cause this when engine is running or shut off? Please let me know if you know any other suggestions?
pgamboa
Dec 24, 2023 11:52 AM
2quiker
Mar 22, 2022 08:36 PM
Customer Service #1
May 15, 2020 08:46 AM
jdunne01
Oct 4, 2015 10:29 AM
Sassinm1
Sep 30, 2015 04:23 AM
