Raptor timing?
Old Sep 18, 2005 | 11:09 PM
iweb's Avatar
Default Raptor timing?
I posted before about a friends Raptor not starting with the starter but will run when towed. How do you time it without using a timing light like the manual shows?
If the timing was off would it not have any spark at all?
Old Sep 18, 2005 | 11:20 PM
1988fast250x's Avatar
u cant! ( at least i dont think)
Old Sep 18, 2005 | 11:43 PM
iweb's Avatar
I guess he was talking about cam timing. He says when he is at TDC both exhaust valves are open a little and he has to go 1/4 turn to close them. Is this right?
He was asking how to time the marks on the cams with the crank mark.
Old Sep 19, 2005 | 12:18 AM
RAPTORAZ's Avatar
Will it start up after it's been run for a while? Or do you mean it will only run while being towed?
Old Sep 19, 2005 | 12:49 AM
iweb's Avatar
Will not start using starter, not even a spark. You tow it and it will start and run good as long as you keep high rpm, slow down the rpm and it quits like your turn off the key and then you have to tow it again. He just called and said the cam timing looks ok.
How do you check the stator? The repair manual shows 3 or 4 different ones.
Old Sep 19, 2005 | 11:05 AM
iweb's Avatar
I don't think a tight valve would cause no spark? When he pulls the plug and lays it against the motor and uses the starter there is no spark. Put the plug in and tow it and it will run fine until the rpms get down toward idle and it dies like you turn the key off.
Old Sep 19, 2005 | 04:38 PM
RacinJason's Avatar
how is battery condition?
cable condition?
Old Sep 19, 2005 | 07:54 PM
sounds electrical... to me get
Old Sep 19, 2005 | 10:50 PM
iweb's Avatar
Changed out coil with another raptor,used battery boost,checked all cables and grounds,and today we unplugged the two connectors coming from the stator and using a test light tried every one of the 7 connections while cranking and no light. So can I assume the stator is bad?
brad wheeler
Jul 13, 2015 11:19 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
